Oil filter removal
thebigsnake
Montreal, Canada
How do you replace the oil filter on a 2000 ACR?
Mine has the frame right underneath it, and there seems to be no other access.
Hoosier Daddy
upstate, NY
Should drop right straight down, unless a Dealer installed the Power steering recall wrong. Which in fact has happened many times. Take it back to the Dealer and have them change it. Better yet put a mark on it and see if they just change the oil only. Search this forum for recall pics and you should be able to see the right and wrong installs.
ViperJoe
Virginia
RUT RO!
I hope it's not that pesky little 999 fu#k-up devil!
999 recall - FRONT ONLY on cars built after the 1st March 1999 to the end of 2000
Both Stacks Blowin'
United Kingdom
Jerry,
If the frame is in the way and you have had the 999 done, the garage has carried out the work in-correctly.
Do a search on 998 / 999 Recalls, read and then call "Viper Wizard". Better still arrange to get you car taken there for the rectification work to be carried out (DC should pay for the shipping!!!!)
Best of luck. :mad: :mad: :mad: :mad:
