Hissses
How are you using the bleeder on the upper hose? Talked to Roe and was told I could do it under pressure or not under pressure and take the bleeder out fully or just loosen it. Let me tell ya taking it out fully with a hot engine under pressure is NOT a good idea! Does enough coolant go past the thermostat byepass when cold to bleed it without it being under pressure? How are you doing it? Thanks for your input.
