Paint code for steel grey?
SamC
Glendale, CA, USA
If you are referring to the color from the 2000 year, it is known as Viper VS6. Mopar also uses the code PS6. Either code will work. If you need the equivalent code for a specific paint manufacturer, I also have those. They are found in the service manual.
As an aside, the paint code is listed on the plaque located on the edge of the driver's door.
Ulysses
San Diego, CA. USA
Viper Steel Gray Pearl Coat
Chrys=VS6 PPG=36447 DUPONT=B9856/B9857 S-W/M-S=55731 A-N/S=CHA00:VS6 S-H= 75415 ICI=KEH6B
BASF, Glausurit, Standox use CHRY code
S-W = Sherman Williams
M-S = Martin Senour
A-N/S = Akzo Nobel/Sikkens
S-H = Spies Hecker
ICI = Autocolor
-RUNNR
Site programmer
District 4, Moon
I do believe the only thing missing from that list would be the crayola color
SamC
SamC
Glendale, CA, USA
I don't know whether the manufacturer codes include both colors and the clear. I suspect they do. I just had my slightly dented and yellowed side sills fixed and painted. I gave the same manufacturer codes listed above to a local body shop. The side sills came back perfect. I can't tell any difference from the rest of the body paint.
