Painted red dash on 94 RT/10?
Gerald
Near Tampa Bay
Give JonB a call at parts rack. He resells Superiordash. The carbon Fiber is bada$$ looking. You can pick up Superiordash MUCH LESS from JonB than you can direct from them (Superior). It's a 20 pc kit covering the dash, steeringwheel, rear speaker area, ashtray, etc. Looks awesome!
Gerald
Rich Detert
Union, MO. USA
Here's a pic of Zippy's (Rob McPhee) dash that I painted.
I just used a 3M red scotch brite pad with soapy water to stip off the soft grey paint (it takes an hour or so but won't damage the plastic).
I then sprayed it with plastic primer, then epoxy primer, lightly sanded it, then painted it.
The black is Organsol black (textured black) and the red is Viper red.
I posted a detailed description in january of this year.
Personally I've seen solid red painted dashes and I didn't care for it too much. A little too obnoxious for me (and I like obnoxious). Another problem is that the plastic isn't perfectly flat and smooth (molding depressions and lines) which shows through unless you fill and smooth them out (That's why they use textured paint from the factory).
