Parking / Ebrake adjustment?
Big Mac
Austin, Texas
I have a 1996 RT/10 with about 27k miles. Unknown when or if brakes were last replaced. When I pull the parking/ebrake it comes right up to it's stop with no tension and no application of the brakes. Is there an adjustment or a known issue that I should check first with this?
LiquoRT/10
The first thing I would do is take off the rear wheels and check to see if you have any pads left.
I wouldn't drive the car until you check them.
Tom F&L GoR
Wappingers Falls
These installation pictures will help you see if the brake cable is unhooked at the caliper.
How to Install
My number is listed on the site if you want to call.
As Dave said, the rachet mechanism inside the handle could be broken, and there is also a cable "T" to connect the two rear cables to the one cable of the handle that could have come unhooked.
What happens if you pull up on the handle while stepping on the brake pedal?
B
Big Mac
Austin, Texas
I have not tried stepping on the brake and pulling at the same time. Will try that asap and let you know.
Red94Roadster
Michigan
I have a similar problem and need some advice. In my 1994 RT/10, sometimes I pull the parking brake handle and it pulls all the way up with no effort. When this happens, I can lower the handle and pull it up slowly and feel tension (i.e. it works normally). I've checked the rear cables and they seem fine? What could I look for at the handle?
B
Big Mac
Austin, Texas
I have found hitting the brakes and pulling the handle works much better. You might try that too.
Robgen1
Must be a 94 thing, exact same issue with mine.
Robert
Tom F&L GoR
Wappingers Falls
The ratchet in the handle must be stuck. When you have the brake on, push the button to let the handle down, the mechanism under the button to disengage the teeth stays disengaged. Then the next time you pull up, since it is not engaged, it doesn't pull on the cables. Moving it probably then loosened the ratchet system so the second time works. just a guess.
Black Adder
Same symptom with my 2006, handbrake works better with foot on the brake pedal.
I had mine checked by the dealer this week and they said "no problem"......but what do they know?
Tony
Tom F&L GoR
Wappingers Falls
I thought the '06 parking brake is a completely separate caliper from the hydraulic brake, so it should not make any difference, ever, whether your foot is on the pedal.
SimpleJack
