Passenger door opener replaced as well as cam sensor
08viperviolet
coral gables FL
Hi just had my passenger door opener replaced and cam sensor on my 08 coupe wondering if anyone else has had any problems with either.
Joshua
:2tu:
gb66gth
Big-D
How many miles on your '08? I have apx. 2200 on mine and I want to know what to look out for
Racer Robbie
Guilford, CT-USA
I am in the middle of replacing a water pump on a 1996 GTS and found that the cam sensor was busted in half where the wiring harness connector attachés to it.
colo08
Had my cam snesor replaced with only 800 miles on the car. Sensor checked out okay when it was removed and tested. but my viper tech said the part is only about $8.00 so he replaced it and my car has not gone into limp mode sense. I'm sure it has to do with heat, so when they test it out of the car it cold.
Racer Robbie
Guilford, CT-USA
In my case above, the customers defective water pump was dripping antifreeze on the can sensor on account of a faulty water pump seal.
08viperviolet
coral gables FL
my cam sensor was tested once before replacing and read like it was working fine. But car has had no more problems since replacement.
