2006 VCA doors won’t open from outside
doliver
Cibolo, TX
Doors on my 2006 VCA coupe won’t open from outside ‍♂️. Anyone had this problem and what is the solution? Thank you all.
D
doliver
Cibolo, TX
I have not. Is there a procedure to follow. Battery is new but I rarely drive it and it sits for extended periods. I do not have a trickle charger for it. Car just went over 4200 miles
D
doliver
Cibolo, TX
Also I’m out of town Till Monday so I will try these things on Monday and update the group.
D
doliver
Cibolo, TX
Update! I disconnected the negative terminal for about 5 minutes, reconnecting and it now works. Go figure. . Thank you Steve-Indy and Old School for your help and replies!
Barry
Kill Devil Hills, NC USA
I had that problem with my 2000 GTS. It started out as intermittent and then they failed completely. Turned out to be broken wires in the loom going through the door. Dealer fixed it the first time under warranty but didn't do a very good job so I fixed it the second time and haven't had an issue since. I ended up making the wires longer.
JLNH
