Paxton internal gear ratio?
Mika
Finland
Hello,
I tried to ask this from paxton, but they don´t reply my email.
I´m looking for a bit more boost, and I would like to know what is the internal gear ratio of my Paxton supercharger? Paxton website only states that the maximum impeller speed is 55.000rpm, but how do I know how fast the impeller wheel revs now with 7" crank pulley and 2.75" supercharger pulley?
And what happends if I go slightly over that 55.000rpm? Does the supercharger just blow up, or does it just lose it´s efficiency so much that it´s not worth it?
I NEED MORE BOOST AND MORE HORSE POWER!!!
Thank you.
Mika
Omaha NE.
Take it to the dyno and plot the boost curve. You will be able to tell when the efficiency drops off. I doubt you will get this info from Paxton. You may also call a "tuner" like DC Performance or Doug Levin as they may have dealt with this question in the past.
Joseph Dell
Atlanta, GA 30338
Hello,
Thank you.
Mika
The internal step ratio on a paxton is 3.54:1. there is a math calculation that you can now do now that you have the 3.54:1 number. you'll see that you are just over 55k RPM. Over 60k RPM on a paxton you can kiss the bearings goodbye. you also can't get much smaller than 2.75 b/c you don't have enough belt wrap to get the belt to spin the pulley. translation: the belt slips.
The paxton only flows a hair over 1000cfm. and with a 2.75" pully, you are already pushing that max. spin it faster and all you'll get is heat.
Been down this path before... too bad there isn't a paxton supercharger out there that pushes more CFM. But there isn't.
good luck!
