Paxton!! Where did you put the fuel pumps?
Whipz
I'm in the process of installing a Paxton on my 05' SRT. The manual wants me to locate the fuel pump setup on the flat area behind the master cylinder. I'm guessing that others have found a better place to put the pumps that is not so obtrusive. Any recommendations?
G
Nader
New York
Someone actually hid them insider the inner fender. I cant remember who. It looked much better than mounting them where is says to.
INSIDE the tank.
the stock paxton fuel system is marginal at best. if you are gonna run more than stock boost, you are really pushing it. be warned.
Bolt
Harrisburg, Pa
GenII
Paul Hawker
San Diego, Calif, USA
D-C (Dan Cragin) mounted mine benind the master cyl. Thought they looked kind cool. Lots of people asked about them, and liked the idea of booster pumps controlled by vacuum.
Guess you could build a box around them, but they really accented the blower theme.
They can be black to go away, silver as an accent, or painted for bling.
W
Whipz
I have thought about painting them for Bling. I just finished painting the valve covers and cross brace "Viper Snakeskin Green" and then polished the 'VIPER' lettering. I think the Booster Pumps may go green too.
For even more bling, my second option is a polished aluminum box to conceal them, or I could put a plexi glass top on the box and even LED light the inside.
Option 3 is to burry them in the fenders.
I just can't decide.
g
Nine Ball
Houston, TX
Mine are located as per instructions. No problems here.
Nine Ball
Houston, TX
Clean filters just mean you guys aren't driving these cars enough :)
That section in the front of the filter is more dirty because that is where the hood opening forces the air. I have a 2008 hood.
ILLSMOQ
SAN JOSE, CA
I've done a couple paxton gen III srt's installing the pumps in the inner fender along with the FMU, relays and other wiring. It's a little more work to get in there but worth hiding all the extra hardware in my opinion. My car has been set up like this for the past 3 years with no issues, heat has not been a problem. If you go this route make sure to protect the hoses and wires frome the sharp surfaces inside the fender and make sure the hoses do not get kinked.
mbccenter
Legacy Supporting Vendor
Forest Lake, MN
Put them down by the trany and engine. Less noise then up top and can get to them easy if need to.
ATLVPR
