Photos - Gen V with Xtreme Supercars aero package.
InjectTheVenom
What variant of the 3M tape did you use and did it require applicator pads to activate the adhesive? I tried 3M tape with red foil for a dash part on my restoration project but the center bit seems to be lifting back off just a bit. The trim part being press fit instead of flush fitment may have something to do with that, not sure though.
JETSTAR
It is the high strength 3/4 3m emblem tape runs around $60.00 per roll
We use 2 strips about 36" long
If you try too pull it off it will break the deck you have to cut it off with fishing line to remove it
ViperJohn
Maryland
Your car looks great.
Also, the airflow Gen 5 picture looks like a snake head.
Jack B
NE Ohio
Neither tape will work on specific plastics that slowly release a mild solvent after put into use. Your dash probably could have used the 3M, #94 primer, it is made for the tape.
SKY1960
