Pic of eibach spring beside stock
Inferno
Does anyone have a pic of the 2 springs side by side, so I can see difference. If you came in here looking for a pic, I put one below, 2 are 345's, 1 is 355. Guess which one is the 355.
LETHAL GTS
Winnipeg, MB
I can tell you that they are shorter by about 1 inch.
After installing them, my car now sits 1 1/4 inch lower than stock. I cannot give you a pic like you requested because the springs are on the car. I hope this info helps with what you are looking for. Let me know if you have any questions.
I
Inferno
Thanks man, do you have a side shot of your car lowered?
I
Inferno
Thanks for pics man. For anyone else interested, here is the difference between stock.
Lowered with Eibachs.
00prowler
Vernon CT USA
sits much nicer than the factory height esp. in the rear...AL... :D :D
Damn, yours looks low, that's just springs?
YEP..Eibachs only..Its not that low..could be the pic...the front went down 3/4 of an inch and the rear went down 1-1/4 inches...sits just right IMHO..AL
Chuck 98 RT/10
tampa, fl USA
They came with the car. The GTS did handle differently than the RT/10 but there are too many variables to determine what the factor was.
LETHAL GTS
Winnipeg, MB
Jeff, check out the pics on my site to see how low the Eibachs lowered #34.
http://www.babelmotorsports.com/MyVipersTN1.asp
Thanks Chuck, pics help decide, I need springs. Did your handling improve?
Yes, it improved my handling. You will need to readjust your damping though.
Mine feels more like a track car, stiffer ride and you can feel every bump in the road. I haven't tracked my car since I lowered it, but I'm almost positive it will be an improvement.
DrDJ
Chesapeake, Virginia
It's tough to tell with the tires so far apart and with the camera relatively close, but I am going to say that the tire on the left is the 355, mainly because it doesn't look as tall as the other two.
Cris
I agree - the far right one. It has more sidewall buuldge. I would be surprised if it added much in tread width.
I
Inferno
Keep guessing, I'll reveal the answer when we get to 10 guesses.
Bob K
Woodinville, WA USA
The tires are not lined up evenly. The middle one is back about 2 - 3 inches and therefore gives the illusion of being taller. That being said, I would still guess the middle one.
Bob K
I
Inferno
3- far left
3- far right
2- middle
time for a hint
I
Inferno
I will post the answer tomorrow. I would like to see 2 more guesses. It's a close race.
bogzie
