problem with the driver window
viper srt10
Qatar
Hello guys
I have a problem with my 2008 viper
The upper edge of the driver's window is always hitting the body while opening and closing the door!!
So sometimes I have to open the Window a little to keep a sufficient gab between the upper edge of the window and the body of the car
How can I fix this problem ?
Garron
Hello guys
As a start, if the battery was low you will need the re-set the body computers window stops. bring the windows all the way down and hold the button until the window stops do the same thing for the up position.
If that does not work, the manufacture procedure involves using a Chrysler scan tool and seeing what codes the Body computer is reporting
possible causes include
window adjustment
window regulator (Hall sensor in motor)
body computer
viper srt10
Qatar
thnx a lot
i will check the possible causes and i hope that i will be able to solve this problem
Borstie
