Question about rear seal
happy
p.e.i canada
Had my 02 GTS into shop Friday oil pan gasket was leaking and got that fixed now The rear main seal is leaking ... My question is does the oil pan have to come back off to change the rear seal when you have the transmission out???
H
happy
p.e.i canada
Also with all the oil on the clutch think I'll put a new one in too just a stock one held up fine does anyone know what brand is the stock clutch??
H
happy
p.e.i canada
Ok so the luk ones I see on eBay prob be the same as what roe sells I would think??
speedracervr4
Lancaster, PA
I would think so, but I would rather buy it from Sean since he backs his products if you have any issues. You may also consider replacing the pilot bearing, slave cylinder, and throwout bearing since you're in there.
viper k
Speed your in lancaster not to far away from where i live iam down around connellsville dunbar area!!!!
merlu
