Radiator draincock - is this it? (kinda URGENT)
DLTARNU
Suspended
Miami, FL
I'm in the middle of flushing my radiator. As I went to open what I think is the draincock (a hex bolt on the driver's side of the bottom of the radiator) I noticed that it has a sealant of some sort around it. It's a dry foamy substance that flakes off easily if you touch it with your fingernail.
Is this the drainplug or should I leave it be? Whatever it is, it doesn't want to unscrew, and I'm afraid to force it too much.
Thanks!
99 R/T 10
Enterprise, AL USA
Don't know for sure, but call you favorite helper(Tator, Levin, Macedo), they should be able to explain it for sure. I usually just take off the lower radiator hose to drain quickly, good luck.
BE CAREFUL, as one can twist this out of the radiator...some suggest a slight tightening first, then gently backing out this 1/4" Allen plug...I usually put a little teflon paste/teflon paste on the threads upon reinstall...some report anti-seize usage, but I'm worried about getting it on the "business end"of the plug...and, as I change coolant regularly, have been happy with the teflon approach.
D
DLTARNU
Suspended
Miami, FL
That's what I'm doing too; removing the bottom radiator hose. Still would like to know about the draincock so I don't unscrew something that wasn't meant to be unscrewed :laugh:
SORRY...what you described sounds like the drain on all of our Vipers...I threw in the size as a cross check for you. Good luck !!
D
DLTARNU
Suspended
Miami, FL
Got it done. Posted results in a different thread (Zerex Racing Super Coolant).
Thanks 96 RT/10, Steven-Indy and Señor Levin for the info :2tu:
