Rear end removal??
evil00017
I want to remove the rear end on my 2001 RT/10. Is it straight forward? Is there a write up for it? Can someone tell me if I can easily do it myself, or if I should get a pro to do it? I am not completely ******** mechanically. All I want to do is remove the whole pumpkin.
dave6666
Remove drive shaft and halfshafts (both at diff and wheel - take them out!). Can't remember if you have to yank the rear shocks to get the halfshafts out but if you do, it's a minor inconvenience. Probably have to remove the exhaust if you have rear exhaust. I have side exhaust on my '01 so when I did my diff the exhaust did not matter. There is a bolt on each end of the diff housing and 2 in the middle. Let it down on a floor jack, wiggling it out as you go. I did mine entirely by myself. When it goes back in be sure and use new straps on the u-joints and to Loctite the screws. You do not have to replace the screws, but the straps are one use only.
Jack B
NE Ohio
Just another opinion, you do no have to touch the shocks, nor do you have to totally remove the half-shafts unless you have a twisted half-shaft, those come out real hard. It usually does not drop straight down, it has to be angled down and is best done with two people.
dave6666
I could not get it to move side to side enough without completely removing the halfshafts. I had zero issues manhandling it by myself with the assistance of a floor jack. Either way you go, it is not rocket science to get out and back in.
Jack B
NE Ohio
If you could not get it out without removing the half-shafts, probably, the half-shafts are slightly twisted and they would not entirely collapse. The problem with a partially twisted half-shaft is that the independent suspension is no longer fully functional. I paint a white line on the half-shafts, if you see any deviation at all, they are binding. In some case you will hear a metallic clunk when going around a corner. In summary, a good half-shaft should collapse enough so that it clears the diff stub shaft.
dave6666
Oh they are just fine in the compression aspect, I just decided that since I was working by myself I'd have a wide path to maneuver through. I'm guessing that's what one of the useful features of the other person is; handing the dangling parts? Whether or not it is "required," it does make it easier ;)
Jack B
NE Ohio
Dave
I have a lift and found the diff is just easier with two, I do use the transmission jack on the trans. You have a good point, the half-shafts do get in the way when you try to angle the the diff to drop it.
SimpleJack
