On my car I will start at 29 front and 27 rear cold. I will usually end up at 28 front and 26 rear when hot. You may want to start at 30 on both ends when cold......They say: if the rear is loose you want more pressure in the front, if the front pushes you want more pressure in the rear. Use the first run to warm the tires and get an easy look at the course. With some heat and the right pressures they will stick real well. Othe folks at the autocross with tire that are not steam rollers will tell you 40-50 psi ..... they are not driving our cars with wide tires and no sidewall....don't listen to them. Let us know how it goes.
