Relay to stop viper starting?????
VIPER BAZ UK
ENGLAND
Leaving for Chucks on Thursday Dont realy want to disconect the battery.
But is there a relay i can pull to imobilise car...
Neil - UK
ENGLAND
pull the engine and ecu remove the wheels, gear knob and steering wheel,drain the fuel tank or alternatively just leave it in my garage and I'll make sure to keep the tires sticky :D
Pull the starter relay in the small box up front (take out the 2 fan relays as well for the obvious reason) and pull the fuel pump relay in the back.
V
VIPER BAZ UK
ENGLAND
Cheers Steve..Is the Is the fuel pump relay in the same place as the Gen1s in the trunk?
Neil Can you collect but it will need fuel as it is empty :smirk: :smirk: ...
Joseph Dell
Atlanta, GA 30338
Easier way: pull the fuel pump relay. In the trunk (at least on my 99RT), there is a relay box to the left of the amplifier. The bottom relay on the box is the fuel pump. pull that and the car won't run for more than a second or two.
This is also a good trick to remember if you want to crank the car w/o starting it (for those of you w/o a bump starter)...
JD
countourcafe
