Removal of inside door handles on '95?
Tom Shapiro
Re: Removal of inside door handles on \'95?
Firmly, push the door handle bezel(cover) back toward the rear of the door. Take the screws out of the door panel and the speaker. Disconnect the speaker. Behind the speaker there is a hidden screw holding the panel on. That's it. Good luck!
Gerald
Near Tampa Bay
Bob,
All you have to do is slide the bezel back take it off, put the carbon fiber peice on and slide it back on. It only takes a couple of seconds to do it. The first time I did it, I called JonB and he told me how to take it off. I wish I remembered. I followed his directions and worked out fine.
Gerald
Greg W
San Diego
Make sure you push in while sliding backward the cover (bezel) that backs the door handle. You can easily break off 1 of the 4 prongs that attaches it the the door panel. I know, I broke one when pulling apart the door to install door poppers.
Good luck
Gregin<u>in</u>
naimsito
