Replace Tire Nuts on Tire Sensors When Changing Tires?
IDM
London
Is there any need at all to replace the tire nuts while the tires are off?
Car is a 2005 with 10k miles on stock wheels. Replacing the rears today
The sensors wont be removed if I'm not mistaken.
Thanks!
Allan
La Junta Colorado 81050
I think he's referring to the sensor retaining nut that you see at the valve stem.
I've had my sensors in and out and reused the nuts with no problems.
:eater:
Flexx91
Houston, Texas, USA
Yep. Wise to replace the grommet when removing the sensors. Wouldn't want the headache of finding out later that you have a leak at the sensor. You can purchase an entire grommet kit off Ebay for about half of what you'd pay at a tire shop.
bluesrt
plus i use a smidge of sealer on my grommets so those little suckers dont seep
IDM
IDM
London
Thanks guys, went to Dodge for a road force balance and they did not remove the tire pressure sensor so nothing was replaced.
Will let you know if they leak at all
JKGiant
