ROE BLOWER guys, just found these
GTS-R 001
California (north)
in my garage
any body interested? I had these in my engine when I had my Roe Blower:2tu:
1TONY1
Dalton Ga. (Chatt. Tn.)
I might be interested. They should fit in a 99 GTS correct??? And, how much?
They will fit if you have external/added fuel rails. Those are top feed. Your stockers are side feed and use fuel rails that are built into the stock intake. The green top injectors are good injectors. Ford calls them 36lb and Roe called them 42lb because of the higher pressure a Viper uses. Oh yea.....I can flow and clean them :D
plumcrazy
ALL OVER
doesnt DC do some kind of porting or something on these to make them flow better ? i kind of remember reading that.
G
GTS-R 001
California (north)
I think DC actually claimed to "blueprint" them , so to speak,, they would flow rate them and then match them as best they could.
Camfab
SoCal
There is a place that can change the flow rates. DC can have it done.
1TONY1
Wasn't DC doing stock Viper injectors ? The plus there is that you would get a larger injector that would still go in the stock intake....as in not spending $$ and trouble on fuel rails. If you already have or plan on rails it would be a waste to have the flow of top feed injectors increased. I would bet that increased flow in a stock injector still wouldn't even touch the flow of these green tops....which are on the smaller side for a performance use injector. Anybody have a modified stocker ? I have a green top like in this thread....we could compare them.
My point relating to 99RT/10's question, why buy top feed injectors and then increase the flow ? Buy larger to begin with or sell the smaller ones and buy larger. If you are pricing used vs used or even new vs new, larger is the same $$ or not much more.
zeeshan_k24
