I had a VEC 1 installed at the VOI. When I got home and had arrived at the settings which seem to work the best(+12 -20),the car would not run on cold start up. I had to reset it to zeros to keep it running. Sean told me to disconnect the battery for a little while, put the settings to where I wanted them and then turn the key to 'on' and pump the gas 3 or 4 times. It had something to do with the computer recognizing the voltage range of the VEC 1. This worked for me and the car has started fine when cold since then.
Steve
