Roll Rar & Head Room
RaceDeck
SLC, Utah. USA
I did a search on roll bars and there are a lot of choices. For those of us that on the tall side (6"3") is there a good, safe bar that does not take away any head room and or is not going to cause any head injury if your head slams back. I do have a 1" lowering kit going in my GTS.
Thanks www.racedeck.com
SAM Team
Greenville, SC
RaceDeck:
Where were you before I did all this U-Coat-it stuff?
I have done a couple of the different type roll bars now in my Vipers. I have to admit I may have lost a little leg room because the seat will not go back as far, I also have the seat lowering kit. I like the style of the one I have in the Yellow Fever better, from JonB(Autoform). It goes up a little higher which keeps your head and helmet away a little better. It also has the double loop design between the seats which to me looks better, is more noticeable and give you more options with the camera. It looks stronger as well.
Check them both out at www.samviper.com. The yellow roll bar is is to pick out the black one in the ACR you will probably not be able to see.
Let me know if I can help!
MES
Sarasota, Florida
I have BRT's roll bar and IMHO it's much less intrusive into the cabin than autoforms. If you want a roll bar because your required to have one then you should consider BTR you can see some pics on my website below.
Edit I've attached some pics for your viewing pleasure
BarryLB
