RT10 Windshield Frame Pin hole covers
Indy
Vancouver
This has probably been done before, but for those who don't like the open pin holes used for the hard/soft top, I used some plastic retainers (a bit modified to make them fit snuggly) to cover them up. They just pop in and make it look much neater.
Just in time for the nice spring weather :D
LifeIsGood
Viper Lane, Arizona
Looks great! Am I gonna have to pull all the info out of you...Where did you buy them? What modifications did you make to them to get them to fit?
I
Indy
Vancouver
Nothing fancy. A plastic retainer clip used for hood liners (had some laying around) .....then some layers of electrical tape. Then a piece of corrugated hose, and finished off with heatshrink tubing - super glue under each layer to make sure it stays together. :D I'm sure it works the same if you used some rubber tubing over the retainer clip, as long as you have something just a little bigger then the hole to make sure it fits nice and tight. You might even find a retainer clip with a wide enough pin to fit without any work to it.
