run flats PSI
cobrapilot
Olympia WA
What's the best tire pressure to run with run flats to help with wheel hop? I was told 1 PSI over the reccomended tire PSI.
Omaha NE.
I like 32-34 psi to make the center of the tire work a bit more and take some of the load off the run flat sidewall.
Mark
Vipermann
Texas
I like 'em at 37-38 psi ... Skip Barber runs them at those higher pressures too.
C
cobrapilot
Olympia WA
That is a big difference from stock to 38 PSI. Does it matter much in a hot climate verses a cold climate?
