Running Too Cool ??
Robert1994
Laupahoehoe, HI. USA
I just had a new radiator installed on my car. It seems to be running a little cooler as might be expected. The other night I was coming back from the other side of the island and up-country it started getting kinda chilly. I turned on
the heater, but could not get any heat. I was able to detect air slightly
warmer than the outside air but nothing you could really call warm or hot.
I know the heat from the heater only comes out the vents under the dash, not
the dash vents, and the dash switch was turned to the correct position.
I can't imagine having to change the thermostat because a new radiator makes it run so cool. Anybody familiar with this problem ??
IEATVETS
Cottage Grove, Wis.
Mine runs too cool now also when the temp. drops. It may sound stupid, but I was told to put a piece of cardboard in front of the radiator but only cover about 1/3 of it. It helps.
You might want to check to see that the cable from your heater control knob has not slipped off of the water control valve on the heater core , as this has happened frequently to many folks...easy to fix by reataching the looped end of the cable to the little lever arm on the water valve.
Cerevo
