Server upgrade complete, move to commence!
Jay Herbert
Sunnyvale, CA
The Server upgrade was completed last night, both CPU's are in and running fine as is all the additional memory. The only casualty was the Events calendar....will need to wait 'till Monday to fix that as the companies Techs are off for the weekend
If you want to get a feel for how fast it is, drop into the New Classifieds
As Tony explained before, he'll be closing down and moving a forums one at a time, then sticking in a redirect to the new forums location...... and then moving the final "General Viper Discussion" forum.
Initially, all forums except the "General Viper Discussion" will be open, once moved, The "GVD" forum will be turned on as well.
So, to summarize:
1) Forums will be closed one at a time, and moved.
2) All forums except GVD will be turned on in their new location.
3) Redirect will be put in place.
4) General Viper Discussion (GVD) forum will be closed.
5) GVD will be moved and turned on.
Remember, you will need to reset your cookies when we move to the new server.
J
Jay Herbert
Sunnyvale, CA
First, it means the forums should be faster
Second, it means that after the forums move to their new home, you will need to follow the procedure to set your cookie. If you don't, you will need to type in your username and password every time you post. You will also not be able to log into CHAT or get you instant messages until your cookie is set.
Kevin ACR
The Motor City
Jay, the classified section you put the shortcut for is fast , and a nice layout. I'm impressed, if this speed is for the rest of the site we're all in for a treat. Thanks all.
C O D Y
Vancouver, WA
No hurry, it isn't that hard to check in there every so often. Just keep up the great work and I'll be patient. Thanks.
