Snake Oyl adjustable sway bar links vs OEM
Invasivore
Ft. Lauderdale, FL
The boots are shot on my sway bar end links front and back. I see that snake oyl sells adjustable links for about $130 less than OEM for the complete set. I'm just not sure how they match up to the OEM links or how to actually set the adjustment on them.
VJR3
"In Freedom"
They are awsome, will match up just fine....................just dont get their bump steer kit.....sigh
fe4snake
Florida
You can measure the stock ones and adjust the new ones to the same height. I just finish installing the adjustable sway bar with links from Snake Oyl.
F8L SNK
Spring, TX.
Adjustable sway bar links should only be installed on one side of the car. The purpose is to corner weight the car with the sway bar link disconnected on the adjustable side. After corner weighting is complete tighten the adjustable link with no play in it.
Just to replace the stock ones is not a reason, can be an excuse however, but the concept was not designed to run them on all four corners.
sassafras
Huntsville, AL
Corner weighting is where you adjust a coilover to balance the weight of the car side to side. I don't think you can cornerweight your car unless you have adjustable coilovers.
xeng yang
