Warfang
My 97 GTS is developing a squeaky clutch. Is this something I can just spray with WD40, or do I need some form of grease to lube it with? Thanks for you help.
My clutch makes a squeaky noise intermittently when its cold outside. Luckily, its rarely cold in GA, so I have just dealt with it. I think I made a post about it way back when, but cant remember what the suggestions were.
could have a bushing on the pushrod going bad, they will usually squeak on their way out...
Lubrication. It works on date night, it works on linkages.
dave... trojans... and PTFE.... how romantic!![]()
eh, not so fast. The squeek is usually from the plastic bushing wearing out, and the metal to metal contact results. If it is left to go... you get to replace the clutch master cylinder after the pushrod eggs out over time. Adding lubrication to this can actually accelerate wear if the lube used attacks plastic.
ugh... i like dave's suggestion better (cheaper, easier), but can't rule out anything. Where do we get the plastic bushings and how would I replace the current one? Anyone want to do an illustrated howto?
Just guessing, but...
Yes Chad, I did have to set my morning beer down to snap that pic. You owe me for this...
Gen I's must be different!!! I can't seem to find the yellow arrow on mine!
I agree lubing it is a bandaid, but the bushing is likely UHMW PE, which should not be attacked by any common lubricants such as WD40, nor the dry PTFE that I suggested.
Sounds like if you can take a looksie at it to determine the condition that may be a good call.
FYI; The bushing is where the clutch master rod connects to the linkage.
Is that not where my Gen 2 yellow arrow is pointing?
I could be wrong with my pic.
What year is your car dave?
