Steering Servo exploaded view
stmf
Sweden
Hi,
I have a small leak in my steering servo. I wonder if anyone know where a I can find an exploaded view image of it so I know what parts to replace?
It is 2004 Viper.
Thank you
Stefan
Just to clarify since many of us may not be as up with the European naming, but are you referring to the pump or the rack? The pump often leaks from the pressure fitting on the top. That's a tough one to replace without replacing the entire power steering pressure line because it uses a "quick connect" style fitting that's really only meant to be installed, not removed. It's not impossible to remove, but it's tricky. If the rack is leaking you'll probably have a hard time finding a diagram with parts listed. They tend to suggest you replace the whole thing or have it professionally rebuilt. You might have more luck asking a shop that does specialize in that. I was trying to find the same thing a while back when I thought my rack was leaking, but I think it turned out to be an o-ring in the pump that was easy enough to fix. Still have a nagging drip somewhere, but haven't gotten the car lifted up to check again in a while.
BarryLB
