Steering Wheel and E-brake Handle Removal Instructions?
Achilles99
Atlanta, GA
For those of you who have replaced a steering wheel or ebrake handle, do you have a set of instructions you could post? Anyone willing to fax me the pages explaining the process from the service manual? I can do a writeup with pictures and put it in in the upgrades section if there's enough interest.
A
Achilles99
Atlanta, GA
Thanks, but I'm just switching from the blue wheel to a black one. You've got some pretty innovative products on your page.
Nader
New York
(1) Disconnect negative (-) cable from battery and
isolate it.
(2) Remove lower instrument panel steering column
cover. (Refer to 23 - BODY/INSTRUMENT PANEL/
STEERING COLUMN OPENING COVER -
REMOVAL)
(3) Remove three screws securing driver airbag to
steering wheel (Fig. 1).
(4) Tip driver airbag outward, then disconnect two
squib wiring connectors and horn wiring connector.
Remove driver airbag.
(5) Remove squib wiring routing clips from steering
wheel (Fig. 1).
(6) Place front wheels of vehicle in STRAIGHTAHEAD
position.
(7) Remove ignition key from ignition key cylinder.
(8) Holding steering wheel firmly in place, remove
steering wheel retaining bolt from steering column
shaft in center of steering wheel (Fig. 2).
CAUTION: When installing a wheel puller on the
steering wheel, be sure the puller bolts are fully
seated in the threaded holes on the steering wheel.
If the bolts are not fully seated in the threaded
holes, the threads may be stripped out of the steering
wheel when attempting to remove the steering
wheel. Take care not to over-thread the puller bolts
such that they contact the clockspring possibly
damaging it.
Also, threading the retaining bolt back in the end of
the shaft until approximately 13 mm (0.5 in.) of
thread is showing between the wheel and the head
of the bolt allows a safe reaction surface for the
puller to work against.
(9) Thread wheel retaining bolt back into end of
steering shaft until approximately 13 mm (0.5 in.) of
thread is showing between wheel and head of bolt.
(10) Install steering wheel puller on steering
wheel.
CAUTION: Do not bump or hammer on steering
wheel or steering column shaft when removing
steering wheel from steering column.
(11) While holding steering wheel firmly in
STRAIGHT-AHEAD position, remove steering wheel
from steering column shaft using puller. Remove
puller, wheel retaining bolt and steering wheel.
(12) Remove two screws attaching lower shroud to
steering column and upper shroud (Fig. 2). After
removing screws, unclip the shrouds from one
another by applying hand pressure along seams
where shrouds connect, then remove lower shroud
from upper shroud and column.
Nader
New York
LEVER - PARKING BRAKE
REMOVAL
NOTE: Before proceeding, review Warnings and
Cautions (Refer to 5 - BRAKES - WARNING).
(1) Block tire and wheel assemblies so vehicle does
not move once vehicle parking brake lever released.
(2) Fully apply parking brake lever.
(3) Remove center console. (Refer to 23 - BODY/
INTERIOR/CENTER CONSOLE - REMOVAL)
(4) Lower parking brake lever handle to released
position.
WARNING: THE AUTOMATIC ADJUSTING FEATURE
OF THIS PARKING BRAKE LEVER CONTAINS A
CLOCKSPRING LOADED TO APPROXIMATELY 19
POUNDS. DO NOT RELEASE THE AUTOMATIC
ADJUSTER LOCKOUT DEVICE UNLESS THE PARKING
BRAKE CABLES AND EQUALIZER ARE CONNECTED
TO THE LEVER OUTPUT CABLE. KEEP
HANDS OUT OF AUTOMATIC ADJUSTER SECTOR
AND PAWL AREA. FAILURE TO OBSERVE CAUTION
IN HANDLING THIS MECHANISM COULD LEAD TO
SERIOUS INJURY.
(5) Grasp parking brake lever output cable by hand
and pull upward. Continue pulling on cable until a
screwdriver (pin punch or appropriate pin) can be
inserted through hole in left side of lever mechanism,
behind sector gear and out hole in right side of lever
(Fig. 68). This will lock parking brake automatic adjustment
mechanism in place and take tension off parking
brake cables.
(6) Remove both rear parking brake cables from
parking brake cable equalizer (Fig. 69).
(7) Disconnect wiring connector at parking brake
indicator switch (Fig. 70).
(8) Remove nut and bolt fastening lever in place
(Fig. 71).
(9) Remove parking brake lever.
Black Moon
Knoxville, TN
techanvi
