Lee00blacksilverGTS
The dealer would throw me out of his shop once he sees all my mods!![]()
Not this dealer...
Tator's Dodge
Sean, thanks for the info!
Now, for us laymen...basically:
My car is running at conditions outside of the adaptive values of the PCM. These adaptive values need to be changed to accomodate my mods. I think you are saying my adaptive values either have not been changed or have been changed to a value that is still not in the range of where the car wants to operate at. So if the PCM has me running rich it will reduce the injector pulse to try to get the proper voltage (and lean things out), but if it has reduced the injector pulse as much as it can and the correct voltage is still not seen, it will not reduce the pulse anymore..it will simply throw the code, having bottomed out on injector pulse reduction.
I think you are also saying that just b/c I clear the code it does not mean I have brought the injector pulse back to the correct operating range b/c I have not zeroed it out...meaning it remembers my lean condition and will stay there. But does this condition put the car in limp mode? Does the car go into limp mode here or simply the leanest/lowest injector pulse setting w/in its range?
Does the car go into limp mode when the light comes on? Or does it remember the last limp mode setting and stay there w/ no light until the 3rd start or so and until we disconnect the battery?
