StopTech vs. Brembo
gb66gth
Big-D
Can anyone tell me why SRT chose to go with two-piece StopTech slotted rotors on the new ACR instead of two-piece Brembo fully cross drilled rotors? Is it a performance advantage or a cost factor?
Viper X
Good question.
Seen a bunch of cross drilled rotors crack and fail at the track though.
BLWNGTS
Ya... I would always go with a slotted compared to a cross drilled!!
bluestreak
Yes, fully drilled rotors are for show, they crack much easier than slotted versions of the same rotor. And stoptech makes better brakes IMO anyways. Though drilled may dissipate heat a little better, it's not worth the sacrifice in life span, better off working on the brake cooling.
V
Venomiss
Guest
This might be a good question for the engineers tech session?
Izover4u
Chicago, IL
How do the Euroteck 2 piece rotors compare to the stoptech and bremebo?
majic26
