ViperBite
To install the Roe Clutch linkage I removed the drivers seat. When I went to reinstall I found (confirmed) that one of the rear studs was completely stripped. I have chased both the nut and stud. Although the nut will now turn it will not hold any load since the major diameter of the stud is well undersized.
My understanding is that these studs are not replaceable. So before I build some sort of sleeve has anyone encountered this problem and found a suitable solution?
