Stronger Springs for Door Pops, is there such a thing?
Tom F&L GoR
Wappingers Falls
The door pops aren't what push the door open, it's the normal latch. The pops only pull on the door latch (inside the door) and allow latch itself to unclick. Maybe try spraying your latch, the grease in there can get dry and sticky?
SNK BIT in WA
Spokane, WA
The install guy who put my door poppers on said; that if I wanted more spring back that I could look in one of the "Ricer" mags for a little spring that you attach to the car and compress when you close the door. It will then push the door open further than what it does now.
ruckdr
Renton, WA USA
Tom, F&L GoR is correct, however if you go the this site: http://www.auto-accessories.com , and scroll down to their product: VPA Model #80358 . This is what SNK BIT was referring to. It might be possible to install this at the rear/bottom of the door. It is a small spring cylinder which will preload when you close the door and help to push it open.
I haqven't neened these yey, but if you park on a slope, the door may not open.
ACELLR8
Harrisburg, PA
Does anybody know if there is any type of stronger springs that will pop the doors out farther when using the door pops.
If so, where can I get them and are they a pain in the but to put in?
Thanks,
Ed
tbone96
