SVS Turbo
We have been working on a less expensive turbo system for the Viper and came up with a very simple solution that has great potential.
So far on the 98 Gen II stock engine we have made 575rwhp and 650rwtq @ 7psi with no intercooler. Air inlet temps on full out 4th gear runs on the road were 115-120 degrees. We are working on an intercooler and will be increasing the boost for even more power out of this simple kit.
This system can be run by whatever engine management you choose. Motec, AEM, VecII, Split second. You will be able to purchase it with our fuel system or you can use or purchase your own. We will have recommended fuel system guidelines. We can install a similar kit on a Gen I and will be developing another system on an SRT-10.
The system on this current Gen II is being managed by Motec and has traction/boost/launch control set and is ready to be tested. Our plans are to place an intercooler in the system, raise the boost and finish the project. When the system is completed we should be close to 700rwhp and 800rwtq on the stock engine. The current turbo is capable of 15psi (we plan on running 12psi at the most) and the alternate is capable of 25+psi
I will be working up pricing over the next couple days and when finished we should be close to half as much as the starting prices of a twin system, and that’s including a Motec.
The cool part of the system right now is that when you open the hood you don’t see anything that resembles a turbo system. The stock air box and tubes are still in place. Very stealthy. Comes in from underneath the stock air box.
We are still building monster turbo kits and just wanted to develop something that is more reasonable with great potential
more to come......
smoothing turned off completely
more to come......
