All you can really do is inspect valve lash,geometry and torque specs.........stand attaching bolts 40ft/lbs,the only way to check that is to remove the rockers........Shaft hold down nuts 25 ft/lbs..........after valve lash is adj. the adj. jam nut to 15 ft/lbs........unfortunately after the fact is a bad time to check as the only way to truley confirm is to go through the complete installation......if you have reason to believe that there is a problem do not assume all is well as the results would be detrimental.It is however possible that you may encounter a lifter chatter soon after install,as the lifters have to be "loaded" and there can be variances.this can be easily resolved by readjusting the valve lash.This is a basic install for the experienced tuner.Being that the reliability and life of your engine are on the line.make sure this is done correctly as different rockers..ect..Arrow,Crower....T&D rollers have different valve stem geometry.T&D are the best on the market for the vipers,installed properly will last the life of your car
