Thanks to many of you, and to Janni and Henry, sales are 'brisk'.
Did you know:
Team Tech makes custom belts for some NASCAR, Craftsman Truck, and other venues? They are also building some custom aplications for HANS device useage. All belts meet SFI-16-1 specs. All are new, and built-to-order. 6 colors for belts...even more for the adjusters and releases, so a great, coordinate look is possible.
As much as I like Janni's all-blue "Pacific Blue X 3" (matches her eyes?) I ordered the darker Royal Blue harnesses, Black webs/pads, and White adjusters/releases. Comes w/ Rotary buckle, ATTACHED TO SUB BELT ! In this way, you are not sitting on, or hitting sidesills with the buckle mechanism.
Lap belts can be ordered with "normal" pull-out lap belt adjusters, or "pull-up" lap belt adjusters. (that squish you down in the seat better, esp. easier to adjust w/ doors closed!)
The snap-in option lets you remove the 2 lap, and sub/buckle sections in a only few seconds. Team-Tech 5-point (non-padded) begin at $169. State-of-the-Art, fully padded sternum to pelvis, rotary buckles, snap-ins, the max options, (Like Janni+Henry) for $100 more. Bolt ins and latch-type buckles (instead of rotary) can also save $60-$70 per harness ! If you ever add a HANS device, TeamTech will modify your belt for a minimum charge.
Our Inaugural TeamTech sale continues thru 3/30.....
See them at www.teamtechmotorsports.com
Click on Racing harnesses......then check out #6001 !
Thanks. JonB PartsRack
Did you know:
