Tire Diameter the Same? (Front/Back)
BlackVenom
Texas
I want to put 19" Forgeline VR1s on my car, but I have a question about tire sizes. The factory front tires of my GenII are about 5/16" smaller in diameter than the rears. Should I try to maintain the same ratio or is the front to back tire height simply a matter of taste?
I am considering 295/35s for the front and 345/30s for the rear. According to the specs, these tires will be about 1 inch bigger than stock, but they are both the exact same size. (27.1 inches tall) I am going with the bigger tires because I want to fill up the wheel wells without lowering the car.
BV
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
Your're going to raise your ride height and the cars center of gravity a half inch with that setup. If you must go to larger wheels go with a lower aspect ratio tire. You should try to maintain the stock diameters front and rear.
Daffy Duck Viper
Austin, TX. USA.
Oh, a good thing to know. Thanks for the info.
Mando9595
