Tire Pressor sensor
Jabbate
Glastonbury CT
Purchased 08 H Wheels and new OEM sensors for my 04 vert. The tie pressures is 29 PSI X 4, the issue is the LO Press indicator is on? CCW promised if they had my VIN # they could order the correct TPS from Dodge as I sold my OEM ones with my other wheels.Is there a fix as the tires are NOT low?
Luke@tirerack
we have seen problems like that in the past because many wheels are not designed to accept the sensors correctly and when mounted inside the wheel the signal can't get to the receiver in the car because the valve stem is the antenna and the aftermarket "fix" is to mount the whole sensor/valve assembly inside of the wheel in some form or fashion. How and where are the sensors mounted on the wheel? ... what has CCW said?
Cape Coral, FL
The TPMS module needs to be programmed for the new sensors. Without your car in hand, no one could have pre-programmed this......... except us ;)
Whiteinf05
