mercury51
any info on tire rotation on 2008
thank you
bill
thank you
bill
thank you
bill
No can do. Different sizes and the belts in the tires should only rotate in one direction--if you're thinking of left to right.
i change my cups from left to right every 2 or 3 events, since the manual states to do it to keep the wear even since each track will wear one side more than the other due to turn configurations. gotta make those puppies last.![]()
What does the owners manual say? Heard the same comments on the Ford GT forum about not being able to rotate, however the GT owners manual says to do it.
Directional or not, radial tires should not be installed after use in the opposite direction.
