TOOOFST Nitrous/VEC1...dyno results (pics)
2001 GTS
Charlotte, NC
Best motor pull before the VEC1 was 394hp/434tq...leaned it out (-16 high) and it made 412rwhp/458rwtq
Here is the motor and nitrous pull (40 nitrous/30 fuel) @ 1000psi
Scotty was a big help with the whole deal, really like the setup
Steve
2001 GTS
Charlotte, NC
hmmm....what about richening up the VEC1 to -10 or so and up the nitrous jets to 42...that would richen up NA and level the fuel more on the spray
TOOOFST
Barrington,il
SteveO,
Your exactly where you wanted to be right now.Go have some run.
Call me when your ready to bump er up to 600RW.
:p
I built that setup for PRTJET,who's now survived by TOOOFST!
There are some video's of PRTJET hanging with SHANKS UNDERGROUND TT CAR!
PRVT JET
streamwood, il usa
It's nice to see that set up again, I made the same power with a 100 shot. With heads/cam I made 689 rwhp with that set-up. Good luck with it.
P.S both Salenoids were rebuilt not to long ago.
Isaac
Jack B
NE Ohio
Scotty:
No flame intended, but, unless I missed something, there is a problem with the nitrous flow. This is a 200 shot, however, the hp falls off dramatically at 4400, any thoughts. There is another 40-50 hp to be had. I would think a/f going rich is more an issue with less nitrous, then more fuel.
Nice looking install.
Anaconda
Well, if you want to run more nitrous, you need to RICHEN up the A/F mixture, not lean it out.
TOOOFST
Barrington,il
ATTN:Nitrous GURU Jack and SteveOOO
This graph is as perfect a/f and power curve as you can ask for with Mr.Nitrous.
1st off:You would show more RW/TQ if your dyno guy hit the nitrous between 2700-3000(just bragging rights mostly).
2nd:This shot is basically a 150RW.On a heads/cam car it might be only a 100shot.A shot is, what it is and whatever you tune it.
3rd:Your HP curve is near perfect across to 5500.
4th:Your a/f is absolutly perfect for nitrous.Remember
you only made one nitrous run,every run after gets
a little richer as bottle presure and vol.drop.
5th:You can easily make more or less power from here.
6th:I'd bet your car is the only car ever with nitrous to
come out and have a perfect run with a/f and horesepower
exactly what you wanted,in ONE PULL.You probably hold the record
fastest,cleanest and most successfull install ever.
7TH:NOT GET OFF THE NET AND GET SOME TIRE KILLS!
BE SAFE BROTHAAA :headbang:
2001 GTS
Charlotte, NC
Haha..yea
Got the box in wednesday...VEC1 installed thursday...Setup installed friday...and on the dyno monday
:2tu:
TOOOFST
Barrington,il
SteveO this same exact set up tuned up ran 10:42 twice back to back at our VCA track day a few years back!By "Butch the Snake"
The car was an 01 GTS bone stock motor with Balenger headers and exhaust!
Still amazing.
2001 GTS
Charlotte, NC
Since I stepped up from a little 75 shot...I'm only using 1 10 pounder...tucked in the side...
TOOOFST
Barrington,il
SteveO Buy a nitrous T valve from Jegs and mount at bottom or just under your drivers seat.Now you can save on 1/2 length of line usage during on/off cycles and be able to turn on when driving in case of attack!You need a 20lber.
