Track Day SRT10 ACR Hot Tire Pressure
WckdSnke
What is the recommended "HOT" tire temperature of a Gen IV ACR with Michelin Pilot Sport Cup tires for track days?
Took the Viper to the track - Cold Pressure was set at 29 psi all tires. Checked hot tire pressure after 20 minutes of lapping - Front 35 psi and Rears 37.5 psi. Hot tire pressure readings remained consistent throughout the day.
Thanks.
I suspect your alignment is OE? 38-39 is the target....... if you have a performance alignment [that flattens your contact patch when cornering,] your fronts will heat up better.
red heat
I'm running 37psi hot on the front and 36psi hot in rear tires. seems to work OK for me. wonder what others are doing.
PAvenomRT/10
New Hope, PA
I strive to achieve equal hot tire pressures (38 psi) on all 4 tires after each track session. Usually by the end of the second session, all 4 are the same pressure which helps to balance the car (09 ACR). Start out at 30 psi cold and you will be pretty close.
PAvenomRT10
