tranny bracket worth it?
Don_
Ontario, Canada
I'm getting a poly tranny mount but was wondering if the replacement bracket was worth it's price? Would you even notice if you had an upgraded bracket or not?
Don
D
Don_
Ontario, Canada
I figured most did both at the same time but I had to ask :)
I haven't seen any upgraded bracket up close, but by eyeing the design does it seem more rigid then the OEM bracket? I can't really see the OEM part being so "flexible" as it needs upgrading...
dave6666
I would put the billet piece as at least 3-4 times stronger using the eyeball-o-meter.
To comment on the impact of in my case doing both at once... I noticed a small improvement 2-3 out 10, with 10 being rock solid. It turns out my completely toasted motor mounts were the final 7-8. But they were of course a wee bit more work. ;)
D
Don_
Ontario, Canada
I'm planning to do the motor mounts too but was pondering what to do with the bracket since I'll be in the area already :)
Thanks for the input.
ViperTony
Motor mounts + Tranny Mount + Tranny Crossmember = 10. Do it!
Jack B
NE Ohio
Don
If you did not order it yet, I have one. It did not work on my car. It lifted the trans too high.
FATHERFORD
Texas
It's just a few extra bucks, Go ahead and get it.
Then you can be part of the EDBBTBCMVOA. (Elite Dave's Big Brake Tranmission Billet Cross Member Viper Owner Association)
D
Don_
Ontario, Canada
Thanks for the info all, I ended up getting the bracket from Dave so I'm the newest EDBBTBCMVOA member :)
webironmongery
