bmw2nv2000
I am planning on adding an underdrive pulley when I install my X-metal TB. Just wondering if they are really worth the money and effort. Looking for experienced answers.
If you get an underdrive set that slows down the power steering pump, you will avoid the much discussed autocross power steering reservoir eruption and underhood fireball. Spinning the pump slower will be easier on the fluid, the pump, the temperatures...
Had a 67 Camaro set up with serious HP. 454, Steel crank, dimple rods, Donovan gear drive, plasma ceramic rings, square port high flow heads, stainless valves, Holly 850 double pumper, Wyand intake, TCI Trans with 2000 RPM stall, dual point Mallory........
And it had an underdrive pulley to drive all the accessories.
Total with nitrous was better than 900 HP.
I got stuck in traffic on the 110 FWY in LA. The engine overheated, ran like hell and was a bear to manage. Only when I was moving at a decent clip did the engine return to normal temps.
Avoid the underdrive pulley.
The underdrive pulley is good if you're at the track with limited run time.
But when you are streeting the vehicle my advice is to avoid it at all costs. The small HP gain to be had by going to an underdrive pulley is not worth it if you drive on the streets.
That, my good man, is the voice of experience.
I could not disagree more. Your problem sounds like a very poorly scienced out cooling system.
Why not try the other end of the crankshaft first... the flywheel? Put a lighter flywheel on and it affects nothing on the other end like cooling, alternator output etc.
You've hit the nail on the head when you said "problem sounds like a very poorly scienced out cooling system".
You see, Dodge has millions to spend on vehicle issues like cooling. They aren't going reduce the cooling flow to below what their engineers have determined as best.
So now someone like you comes along and says it's OK to reduce cooling flow because it gives you a few more HP. But are you one of the engineers who designed the coolant system in the Viper?
I doubt you are. So why are you second guessing the designers? Don't you think they did all that was practicle to eek out the maximum HP for these vehicles? Do you know better than the engineers at Dodge? They have millions to spend on problems like this. How much did you spend on this problem?
If an underdrive pulley was a practicle option for a Viper they would have included it.
I suggest you put one on your own personal Viper and then come back and report your results to this forum.
I installed my X-metal TB It looks nice and thats about it. Dynoed less power Less torque. A different day but no matter still less across the board. I am thinking of going to the bbk 67mm I think the single bore may take away some of the low end torque. Disappointed yes....
How much UD cost and how hard is it to install? Mechanic job or can it be done in the garage with instructions? If mechanic needs to install it what will be the total package UD plus install cost? Trying to figure out if additional 5Hp increase worth the money and effort?
. Easy as that
