Upper Radiator Hose Bleeder Kit
MTGTS
Orlando, Fl
They were discontinued because they fail frequently. Most if not all vendors stopped selling them.
ViperTony
The link you referenced is the kit and it looks like he still sells them. I do know he discontinued the silicone radiator hoses with the built-in bleeder due to leaks and this new kit is supposed to be better.
M
MADMAX
UK
I think you've hit the nail on the head Tony.
It's the silicone hose bleeder that's discontinued, replaced with the one I list above.
EllowViper
Valrico Florida
Mine went ****-up earlier this year. I just ended up cutting out the leaky bleeder section and replaced that section with a lower radiator hose drain kit (just turned it upside down - drain valve oriented up- and installed on the upper hose). Now I have a HD bleeder valve where the old ROE bleeder value used to be. I believe the OD of the kit was 1.75" and the silicone ROE hose fit perfectly when spliced in.
Neil - UK
ENGLAND
they are mde over here for Roe Ade by SFS, speak to Baz he has a friend who works there :)
GTS Warp
New Mexico
The new improved bleeder in the link works great. I put one in a few weeks ago and it rocks. Easy bleeding, no leaks, and great design.
SimpleJack
