Valve cover insignia maintenance
okloneranger
HELP - :eek: Anyone got handy tips on cleaning up and keeping the aluminum insignias on 2nd Gen.valve covers clean and corrosion free?
dave6666
Tiepilot
Lilburn, GA
I gave up on trying to keep them shined up. They are magnesium and corrode with air contact. You can sand all you want but they will return to a tarnished state.
Newport Viper
Newport Coast, CA
Before 2000 grit paper
After 2000 grit paper
Edward 96GTS
Monterey, CA
best sanding block is the wifes nail file. it is about a 1/4 inch thick and 1 inch wide. feels rubberish. i cut it into 2 inch lengths. works like a charm
ed
Kenneth Krieger
Metro Phoenix
I used the little platic box that the Valve stem caps come packaged in. Just took emory cloth, stretched it over the edge and went to work. Was careful, didn't have to tape anything, and took about 20 minutes, came out beautiful.
PittsburghRT
Pittsburgh, PA
I see there are different types. Which one did you use?
I use the Wenol in the red can or tube.... All Purpose Metal Polish. You only use a small dab at a time on a rag. I bought a quart can a few years ago from Summit and it comes in handy to have around the house too.
propsail
Connecticut USA
Just tried this stuff, and unfortunately, it did nothing at all for improvement to the finish.:dunno:
D
DAMN YANKEE
Guest
PROPSAIL, You would need to follow the Illustrated and get it down below the oxidation before you can keep it up with just a light polishing.
Chris(NJ)
Central Jersey
Theres some great suggestions already in this thread, but I typically use either clearkotes metal polish or megs billet alum polish for any metal work. You can also try some wd40 when the area is still hot :2tu:
dave6666
I'm gonna have to get after that front lawn...
Actually, with the forecast today for sunny and 65, we're taking the GTS to Car Toys to discuss "options."
Screw yard work.
Hoop
Westerville, OH
2000 grit was a great tip. I did that with a sanding block and I used high heat clear with a q-tip to put a coat of protection on.
GBS
South Florida
Like Newport Viper I buffed them out using 800 to 1000 to 1500 to 2000 grit sandpaper and a sanding block. I taped the painted part as best I could using blue painters tape. After sanding I applied a couple coats of Klasse All-In-One. They look better then like new.
LifeIsGood
Viper Lane, Arizona
I wanted to give a big THANKS to DAMN YANKEE for his Guide and Photos for Valve Cover Viper Logo / Intake Ribs Refinishing. I also wanted to share some of my before and after pictures...
Materials...
wetdry 400 grit sandpaper
wetdry 600 grit sandpaper
2" blue painter's tape (masking off engine)
3M spray adhesive (adhering sandpaper to blocks)
1 1/2" x 4" sanding blocks (2)
Breakfree CLP (Cleaner/Lubricant/Protectant, applied after clean-up)
picture.php
Sanding blocks...
picture.php
Remove cable bracket (7/16" wrench)...
picture.php
Remove two interior lower windshield cover screws and lift with painter's tape roll...
picture.php
Taped left side...
picture.php
Taped right side...
picture.php
After sanding, both 400 and then 600 grit...
picture.php
After sanding, before cleanup...
picture.php
Before - left valve cover...
picture.php
After - left valve cover...
picture.php
Before - right valve cover...
picture.php
After - right valve cover...
picture.php
Before - viper close up...
picture.php
After - viper close up...
picture.php
Before - viper logo close up...
picture.php
After - viper logo close up...
picture.php
Before - manifold ribs...
picture.php
After - manifold ribs...
picture.php
MTGTS
Orlando, Fl
I did mine as well using a small sanding block on mine as well. Let the bock do the work and don't press to hard. I was also doing while everything was wet so far a little added security. Afterwards I used some wheel wax on on all the metal to slow the oxidation process
Larrybf
