Water ****, installation question?
Viper23
I Have a friend who is installing his water/**** system for the Roe blower and came up with a very good idea about installing it using the windshield wiper fluid reservoir. He has a couple of questions:
1) Where would you mount the pump? Example, on the top of the foot box next to the VEC2 controller.
2) Besides capacity issues, are there any other issues or concerns that might arise due to the fact that he is not using the reservoir that Sean provided?
Thanks in advance
Be
Joe Dozzo
Golden, CO
You'd probably want the pump inlet lower than the washer outlet so gravity keeps the pump primed - as in the trunk configuration.
The pump is a pretty big unit. I'm not sure the hood would even close with the pump mounted on top of the the drivers footwell.
