Weight of 5 spoke wheel
N2 Vipers
Fresno, Cal USA
I know this has been around many times, but can anyone tell me the weight of an 18" 5 spoke wheel (front) off of an 08?
Thanks in advance, John
N
N2 Vipers
Fresno, Cal USA
I was told at VOI 10 that the new 6 spoke weighs about the same as the ACR wheel. Now how much does the 08 5 spoke weigh? 35 lbs sounds heavy for a front wheel?
ulllose
Brunswick, Ohio
Not sure on the 5 spoke but if everyone else say they weigh the same as the 10 spoke here is one that I weighed with run flat and sensor. 18" front stock wheel
N
N2 Vipers
Fresno, Cal USA
The ten spokes are heavier than the 5 spoke and the razors, but by how much? They can't weigh 58lbs????? Is that 58 lbs with the tire on it?
rcl4668
Oregon, USA
Just confirming the above posts; the most recent SRT chat confirmed that the new 6-spoke rim weighs about the same as the ACR/Sidewinder/Copperhead 5-spoke rim (not to be confused with the 5-spoke rims that came standard on 08s). The ACR/Sidewinder rims weighs about 17.5 lbs front and 25 lbs rear.
ulllose
Brunswick, Ohio
That is rim/tire/and sensor............the only thing missing would be the weight of the lugnuts,
I did not dis-mount the tires so i have no idea what just the rim weighs
wallbanger
if u go to the link above on "razor wheels" it has the weights of the 10 spoke , 5 spoke and even the run flat tires....
potterb4
