dave6666
...especially given the content of your posts.
Which I reserve the right to never make stuff up that people didn't say and then attempt to make a fool of them.
Try it.
The reason for the epoxy is that the area behind the sill ( after investigation) was found to be corroded to the point that it was through half the thickness of the aluminum sill...2 different body shops gauranteed the epoxy as that was the only option short of welding a new piece in after cutting the old one out. They both decided that a weld attempt could cause the area to collapse due to the thinning from corrosion.
Piper![]()
