What Does Detonation Sound Like???
ViperRichRT10
Suwanee, GA
Can anyone tell me what detonation sounds like? I have a Roe SC and a somewhat loud exhuast. What does it sound like from the drivers seat at wide open throttle????
Thanks,
Rich
PhoenixGTS
Phoenix Arizona
Like the car's teeth are chattering in general, but I have to admit I've never heard a Viper rattle before.
Joseph Dell
Atlanta, GA 30338
Know that thing when you push the gas pedal down? it sounds like that... :)
think school bus going up-hill sounding like a bunch of marbles.
if you are worried about it, put in a few gallons of 100 octane and that should clear it right up. or we can take some timing back out...
JD
V
ViperRichRT10
Suwanee, GA
Could it sound like sand in the front fenders? Of course there is no sand on the road. It just sounds like that when I mash the gas.
Kiaser
random ticking, sometimes not very audible. Sounds like tiny rocks coming up and hitting the firewall in front of your legs.
V
ViperRichRT10
Suwanee, GA
JD
JD, Maybe we should take some timing out. It is a high pitch, tinny, sandy sound????
Dimitrios
Queens, New York
get it fixed. i couldnt get dyno time and my pistons went. i had detonation for most of the summer. now the motor is opened up and its costing me a bomb. get it tuned right!
V
ViperRichRT10
Suwanee, GA
Dimitrios,
Does what I describe sound like what you were experiencing?
Mr Hemi Head
Bluemont VA USA
A wideband A/F monitor would be helpful especially with the S/C.I'm using a Wideband Commander and there are others. It provides some peace of mind and is a must for tweaking the VEC2. Rick
ruckdr
Renton, WA USA
If you can hear it, you are definitely doing damage!!!!!
Even if you can't hear it damage is being done - get it fixed !!!
Later,
Warfang
California, East Bay
When I hammer the gas on the freeway, I hear some chattering noise. Sounds like detonation, but feels like it's coming from behind the car. Could it be something else? I only use premium gas.
PhoenixGTS
Phoenix Arizona
Joe Dell's suggestion of running some 100 octane would be perfect in your situation. Run the tank down to almost empty and throw in 3-4 gallons of 100. If the noise goes away in the same conditions that is a real good indicator it was detonating. If not time to look for another cause.
Simms
Pittsburgh, PA
When I had detonation it sounded like a tiny vibration noise from under the hood.
Look at your plugs. Detonation can show up as tiny little round specs on your plugs.
1TONY1
Dalton Ga. (Chatt. Tn.)
Detonations sounds like small gravels itting the front wheel wells....like driving on a freshly paved road. Rich, you DO
NOT want your motor doing that....the pistons will easily break.
Warfang
I'm in ******-California... where do I get 100 octanes? :confused:
Dimitrios
Queens, New York
Dimitrios,
yes it does...mine did it at around 4500rpms and higher. get it tuned...
V
ViperRichRT10
Suwanee, GA
Thanks guys! It sounds like I do have a big problem.
JD,
I'll come by this afternoon so we can adjust...
Thanks,
Rich
King RT10
Florida,
"Could it sound like sand in the front fenders"
Sounds like you are describing the front air dam suction not detonation.
aslowdodge
erc racing fuels in San Lorenzo. Buy by the drum if you like. Theres a few stations like the 76 in san jose off of almaden that sell 100. You're NA I think, so you shouldn't need it.
Schulmann
Canada
Yes it is like sand hitting the fender.
Retard your ignition a couple degres (2-3).
